I have a piece of borosilicate glass and I need to laser mark some letters into the surface. Is this even possible. I want to be reasonably certain it can even do it. I saw some other articles, but I know little about glass, I was hoping someone can tell me if this is possible and what it might turn out like
You’re definitely going to want to test. In general folks have had better results after coating class with soap - not exactly sure why though!
This might be of interest (from way back)
Well I have managed to successfully figure out how to mark on borosilicate glass and the results are very good (still shooting for perfect). I also can telling 501 settings to NOT use on borosilicate glass…unless you want to destroy your glass that is.
Now to figure out where to post the final settings when I get done??? Here?
Yep. Beyond the Manual is the place for non-PG material settings. ![]()
glenn2,
Did you fine tune your settings to etch Borosilacate. I am ordering K9 Borosilacate glass Christmas ornaments to etch on my glowforge pro. Even a starting point that I can use to experiment with my own settings.
Gerald
Are you looking for a surface etch or are you looking for something deeper?
| holtflight400
September 19 |
glenn2,
Gerald
glenn2,
Sorry for the long delay in responding. I did not see the notice in my email that you followed up until tonight.
I only need to surface etch Borosilacate. I am able to convert a color image into greyscale and etch images into simple glass reasonably well. I am hoping to use a similar process of processing an image for Borosilacate etching, but do not have much to start from beyond experimenting starting with my glass settings. I appreciate your guidance to avoid destroying a lot of K9 crystal blanks.
Gerald
