I picked up a roll of this Perfectear tape at Signwarehouse:
https://www.signwarehouse.com/c/perfectear-plus-medium-tack
(Problem with vinyl transfer tape is it’s much too high tack and thick for masking. Great for transfer of vinyl bits though.)
I’m using Ramboard tape right now. Locally available, sticks to most surfaces, sometimes too well. Adhesive loses tack when in contact with Enamel/Lacquer solvents though.
http://www.laserbits.com/sus-190-liquamask-pint.html
There is this. I don’t know how it works but I’ve been dying to try it. Send me a laser and I’ll test it out and report back.
I have used masking tape but mostly use blue painters tape. No issues (except weeding afterwards and that’s solved by using some Gorilla duct tape). Is the laser properly focused? If I think about it I may bump the power up 5% or slow the speed a bit but I usually don’t so the tape really doesn’t make much difference.
Don’t use transfer paper so can’t talk to that except that other laser folks I know haven’t mentioned it being a problem for them.
I have access to a CO2 laser cutter at work, and I’ve used the kind of painters tape they make for 3D printing beds. It’s the same as regular painters tape, but it comes in sheets, rather than rolls, and is much wider, therefore saving you a lot of trouble in applying!
I found that it works pretty well with plywood, getting rid of the darkening around cuts. Cutting speeds and power don’t need adjustment, but if you’re engraving through it make sure to adjust speed and power, as the laser is going to have to burn through the tape first.
Here’s one of the previous threads aboot masking…
And I’d like to second this…
[quote=“smcgathyfay, post:3, topic:4306”]
Describe what you mean by doesnt do well.[/quote]
It dosnt seem to burn away and leaves a lot of residue in the engraving portion. I would expect it to just disappear just like the wood does as it engraves but it dosnt seem to. I think it is more of the glue than anything. I primarily want to be able to engrave with the masking and be able to paint it while the masking is on, and also minimize the amount of smoke that gets on the wood(I have minimized most of this adjusting speed and power). Just looking for something that works for y’all and is in wide sheets like the vinyl transfer paper. I am looking for 12-18" wide rolls if possible. The bed of this laser is 24" x 24" with adjustable z axis so I am putting fairly large items in it.
I wanted to try the liquid stuff too.
There are many different tape manufacturers, you may just need to change product-lines, or brands. A lot of the paper-based transfer tapes for vinyl lettering look the same on the roll, but the paper and adhesive formulation can vary a whole lot.
The masking on the ProofGrade is thinner than masking tape. It has more of a cloth feel to it than the plastic feel of masking tape. The adhesive is somewhat like a film that is tacky but very smooth. It comes off the finished plywood, hardwood, leather and acrylic perfectly without leaving any indication that there has been a masking on.
The masking does make a difference for finished goods and especially for leather.
I have some walnut of my own that I prepped and might not worry about the masking since I can clean it up after the print and finish it how I wish.
When I get back in my office next week I can check the brand, but its pretty thin so Im thinking the stuff you have might be thick with thicker glue.
So I’m still big on materials other than though I will be using quite a few of those, I am sure. Since masking is sometimes very useful with
I am curious which, if any, of these products have been used by beta and pre-release users in conjunction with materials other than
and how well did it work?
Frog Tape. Big time.
The Blue Masking tape will also work and it’s a lot cheaper.
(Also use a lot of the Scotch ATG 714 tape gun with double sided adhesive. Well worth the price of the gun if you do a lot of paper work or other light materials. Holds it down and can be rubbed off after, or just used to adhere the paper to whatever you are going to stick it to.)
Good to know. These are very common at local stores, and I was hoping that they, especially the Frog Tape, would work well for masking when not using materials.
Now I just need something that allows me to store specific presets retrievable by custom QR code.
I use the frog tape more for holding down papers at the edges and trying to keep jigs from moving around.
If you want to use a masking tape - you can buy a roll of paper masking tape (like 12 inches wide) a whole lot cheaper than the frog tape.
It’s not as tacky either, which you want for removal.
I would link you to the stuff I’m using, but it actually is a little too light on the tackiness, and I’m going to need to find one that has a little more sticking power.
I’m sure between craft and home stores, I can get plenty of cheap paper masking, too. I guess some of it will be guessing and testing for preferences, too. I expect to have a LOT of fun once I get everything worked out for my apartment and am ready.
@jules, have you tried using a squeegee (you should definitely have one of those ) or credit card to smooth down that less-tacky tape after you apply it? I have a big roll of something similar that I thought wasn’t tacky enough until I started doing that. If you do that, it won’t peel up until you are ready–performs pretty much like the Proofgrade stuff. You do have to put a little elbow grease into the squeegee-ing.
Definitely need to get one…I keep getting busy and I just forget.
I’m usually doing PG stuff anyway…that’s got good adhesive.
I’ve used plenty of blue tape to hold stuff in place. Worked well and as mentioned is super cheap
A print brayer works well too. Either hobby/craft stores or Amazon for under $10.
