I’m doing some research about making my own plywood with veneers. I was wondering if anyone knew what glue would be safe to use with the laser?
I’m looking for the answer to this as well. I plan on using 1/8 hardboard/mdf with veneer on top, then cutting together. I can’t find any info anywhere about what glues would be best in regards to safety as well as cut-friendly. Did you find anything out, @toriemarie?
Not yet. I’ve been busy on several other projects. I’ll try to remember to let you know if I find some info.
