So I wasn’t sure how this would turn out but I made a leather Stamp. I double cut the acrylic and then cut out a second acrylic circle and glued them together. I glued a solid steel rod to the end to make sure I didn’t loose as much power as possible. It was spent enough that it almost cut all the way through the 3/4oz veg tan leather. I had doubt but it’s possible. The stamp is about an inch wide.
Came out great!
Thanks for sharing the results of your experimentation. I think this technique has some real possibilities.
Love this. Do you own an Arbor press?
Thanks Jimmy. I don’t own an Arbor press. Not going to lie, i had to look that one up
I am running out to Hobby lobby. When I get back I will post pictures of my modified Arbor Press. I had a local machine shop set it up to hold stamp handles.
I apologize this is a little bit late but here is my post about my arbor press.
