I have quite a few leather tools now, and it seemed only fitting that I make a tool bag/pouch for them. I thought this turned out well, so wanted to share the design in case anyone else would like to try to make one. You could use this for any smaller tool, ideally one that is around 4.5 inches/115mm in height or so (which is about the height of the tools I have in it). I am sure you could easily adapt it for other uses if you want to, feel free to modify the design as you see fit.
The design of this allows for about 20mm or so of “pucker” for room in the pocket, so you will notice that the pocket piece is a slightly larger size than the back piece.
I wanted it to have a bit of a rustic / utilitarian look so I decided to use the flesh side of the leather. So when you are cutting out the main (largest) piece, you can cut/engrave on the flesh (fuzzy) side up / grain side down.
To make this design you will also need to use rivets. I used a mix of the nice copper kind (that really hold down well, for the pocket) and some of the lighter kind for the strap which I think are a bit more decorative and don’t hold as well, but are fine for the strap. I also used a tiny bit of glue on the bottom part of the pocket, to help keep the leather from overlapping where the buttons are (which are intentionally recessed).
I hope the pictures are self explanatory on how it goes together, but if you have questions please reply and I’ll try to answer. My general approach:
- Laser cut the design. First cut: Main / Large piece flesh side up with engraving.
- After that, cut the pocket and straps grain (smooth) side up. Optional: Add your own engraving or stamping.
- Rivet the left side of the pocket. Then rivet the right side. Allow the leather to “pucker up” in the center, and put the final rivet in.
- Apply some glue to hold the bottom of the leather pocket in place so it doesn’t cover the recess for the button.
- Set the buttons in on the bottom of the main piece.
- Rivet the straps together as pictured using the smaller/decorative rivets. Everything should snap together.
- Put your tools in- you’re done!
I have links below on everything that I used for this project. I also used a button/snap kit to keep everything together. I hope you enjoy it!
This was designed for a thicker/heavier leather (7-9oz), but I don’t see any reason why it wouldn’t work on a lighter weight, though I’d use at least 4oz leather.
Leather: Amazon.com
Copper Rivets: Amazon.com
Rivet/Burr Setter: Amazon.com
Snap/Fastner kit: Amazon.com
Rivet Kit: Amazon.com
Leather Cement/Glue: Amazon.com
Design File (PDF):
LeatherToolPouch-SinglePocket-All.pdf (44.7 KB)
