I wiped up this cool Mandalorian acrylic LED plaque the other day. It turned out pretty well I think the image I just found online. I engraved it on a piece of scrap acrylic built the box out of scrap cheap plywood then covered it with proofgrade walnut veneer. Then wired up a couple of blue LEDs I had laying around on the bottom. I also made a short build video if you’re interested https://youtu.be/QyBk1TLO6Jw
Fabulous! The horizon line in the Mando name really shows because it catches the light
Looks good. What does the original image look like? Did you do anything to the image to make sure the light reached the top of the image?
I show it in the video it was a 2 tone black and white image all I did was remove the background.
Just saw the link. I’ll check it out. Thanks.
Thanks for showing us your video.
It turned out great!
