I made a levitating LED Infinity Mirror using Glowforge and Arduino. I’ve never seen anything like it, so having a Glowforge allowed me to quickly prototype and experiment with the idea. I went from from idea to final product in under 3 hours.
Here’s a video of the floating infinity mirror in action:
And here are some pictures and descriptions from the build process:
First, I tested my LEDs (Neopixels) sandwiched between two semi transparent 1/8in acrylic sheets:
Then I designed the box for the LEDs using Autodesk Fusion 360. The box consists of :
- 2 sheets of semitransparent mirror acrylic cut out as circles
- 2 sheets of 5mm MDF cut out as rings
- Aluminum tape holding everything together
This is a rendered model of the box:
I then put the LED strip inside along the inner side of the rings and tested it out with Adafruit Trinket circuit board (Arduino):
Finally, I 3D printed a stand for the box. It is pretty simple and holds circuit and LiPo battery together. I tested 3 different variations to find one more stable than others. Turns out disc base makes the holder very stable:
And finally all put together and floating in the air:
Completely messes with your senses.
