Hi -
I have 8 of a particular design that I would like to print. I made an 8-up in illustrator and created an svg and couldnt get it to print.
I had an svg of 1 up which I was able to print individually and then if I copied and pasted it in GF as an 8-up.
The only concern is that when I copy and paste it, I am not aligning everything so things are on the same plane. If this was the case, I think the GF might go across the bottom 4 and then engrave those as a whole and then work it’s way up to the top 4. Right now everything is engraving 1 at a time and then moving on to the next design.
If everything was lined up in my graphics program and then on a nice grid - would the GF still engrave them one at a time or would it go across the row and build up… and most importantly, would this even impact (in a positive way) overall print time?
Thanks!
