Lion King theatrical masks
I do a lot of work in local theatre, and when my daughter was cast in Lion King, and the director asked if I’d tackle the masks for the main lions, I put the glowforge to work.
I give you: Scar, Mufasa, Nala, Simba, and Sarabi.
IMG_4915
These are layered cardboard, painted, and then glued to flat foam insulation. More insulation is used as a support to mount them to upside-down golf visors, so that the masks will appear to float above the actors’ heads when they wear them. Scar’s mane is 1/8 inch MDF (so that they stay sharp through the whole run) and Simba’s mane is raffia and wooden skewers.
The masks are FANTASTIC! Thank you for sharing.
Whoa! Great work!
Those are beautiful!
Some incredible work!
I never saw cardboard look so good! Really a stellar job. I’m assuming the theater folks were highly pleased.
Amazing work! Inspiring! :sunglasses:
Those are excellent! (My fav is the second one.) :grinning:
These are amazing! Lion King is one of my favorite Broadway shows. It’s simply stunning. I can’t believe you captured so much of that magic in cardboard!
Looks like the circle of life goes on.
Beautiful work!!!
Really beautiful, They will be amazing on stage.
you are really tweaking what you can do with cutting something as delicate as cardboard. kudos to you. great design work!
just simply amazing and detailed work, thru and thru!!!
Wow. These are amazing. So impressed.
