Cut
5% / 80 / 2 passes (need to play with this still scared of fire ha)
Engrave ( would prob go a bit more power or a bit slower for slightly darker
1% / 335
The infamous corner issue (power is too high in corners and burns through)
Cut
1% / 335
Nice design!
The corners, backlit, think about it
So @dan are these power numbers sorta/kinda ones the rest of us might want to consider using, or at least starting with?
I would say these are really conservative, ideal numbers will almost certainly be higher. But you can see the results for the numbers I used, iterate as needed!
