Machine getting stuck in either the "centering" or "homing" function between prints
That sounds like WiFi signal dropping. If it happens during a command that is being sent back and forth from the cloud, the machine can get hung up, and then it won’t resume automatically.
There are a few things you can do to improve the WiFi signal on your own…the instructions are listed here:
It comes down to how much interference you’re seeing from other devices in your area while your machine is sending or receiving information. (That happens during startup, calibration, scanning and after the file preparation stages. Try to not interrupt those processes and it cuts way down on the times you’ll see hangups with the machine. Wait a minute or so after a print finishes before you open the lid too. Give the machine time to take and send the post print shot.)
