Is that like being close to the dog when you break wind and shift the blame.
Great idea! Blame it on the blacksmith!
The coins Iām doing are either basswood or something similar. Never smelled burning basswood just burning bass!
I had a thoughtā¦itās a makerfaireā¦you canāt be the only one putting off āsmellsāā¦right? (no thatās not a hygiene jab)
smells galore
My first thought was those automatic air freshener things! Set it to release nice scents every 5-10 minutes hahahaha
HI Jonny_firebrand,
Make a box connect the hose on one end doesnāt have to be large and go to the pet store and get the filter pads they use on cat litter boxes. There are not that expensive and may just work okay (get the ones with charcoal). I would make the box long but just about the diameter of the pipe coming out of the glowforge. The forgeās fan should be able to push through air. I would take extra so you could change them out. You may want to try it a head of time. You can also get hepa filters from box stores, but make sure to get the ones with charcoal as they help remove orders more readily than just the particle filters.
Have Fun -D
Edit you may want to put more than one in line inside the box.
Ha Love it, I canāt wait to try eastern red cedar
Every other job, cut a tray of āBacon Chuck Norrisā and balance the smells out
Thanks everyone for your help! I think Iām gonna test out @jkopelās idea with the chimney. I actually was just helping tear down a house this weekend and there was some 6" ductwork I snagged. Iāll seal one side and cut a 4" hole to accept the exhaust from the and then place an inline fan up towards to top of the 5ā stretch to draw and dissipate the smoke. Iāll post pics after I get it together!
