Making a box larger than the print area
Depending on what you eventually want to do, when I ran into a similar type problem I ended up going a very different path. (Cajon made with a Glowforge)
Basically, I cut out a template for a box joint that I could use on the sides, and used my tablesaw to actually cut the sides out.
