I’ve just ordered my Glowforge last week, but have been following the community for quite a time now. One of the reasons I chose to order the Glowforge is this community, as it is one of the aspects I really like of my Ultimaker 2, a community that supports and helps each other.
I think I might be able to add on the original question of this topic.
So you will engrave your stamp on a material you like, my guess is acrylic suits for this (a material you can engrave nice but deep as well), and you use this as a cast for the Instaplate.
I think the results using this material will be nicer than using the clear polymer, and will greatly reduce engraving times (as you make a cast(which again can be used multiple times), not the stamp)
Hmmmm. Hate to say this, but I don’t think this stuff works the way you think it does. It is a photopolymer, which means that you need a negative and a UV lamp to develop it. I’ve never heard of casting photopolymer into a mold. I suppose you could but I worry about getting the stamp out of the mold in one piece. If you have any references on doing this I’d love to see them. Maybe I’m missing out on a good thing!
I do have some of this material from a different company (ImagePac) but it works the same way as Trodat’s stuff.
Hi,
I guess your right. However, I still can see some use for the Glowforge in this process. If you draw something on a dark paper with a white pencil, you can you the trace function to cut-out the drawing. Then you can use this as a mask for curing the photopolymer.
I find it interesting how many new things I have learned being a part of this forum. This sure looks like a lot of fun and if a process can be developed for the Glowforge, likely to become a very popular use case.
Oh, for sure. It might be possible to just go ahead and fully expose the ImagePac then engrave it directly (image reversed) with the GF. I certainly intend to try, having a stack of them here.
The ImagePac doesn’t give as nice of an art stamp as does the resin you pour (from Jackson Marking Products/rubberstampmaterials.com), but it is a bit neater and more convenient.
yes Jeremy, I saved that page as well…just hoping this machine will do what I want it to…so that I won’t be out of the money that I should have put to another machine…now I hear the time frame is at the end of June…while I am a patient person I sure would love to know if it will work…
At Playstation, in the FabLab, we had a Universal 25 Watt laser and that’s what I used. It turns out that if you work for a big corporation and write to material providers with your corporate email and ask nicely, they will send you free samples of various laserable materials.
I called and talked to them before ordering - the product is photopolymer that they have fully exposed and processed. I was wondering if it was a different product than the polymer I receive when I order from boxcar but apparently it’s the same thing
