I really like to see easy ways to avoid buying specialized hardware, especially when the specialization of the hardware leads to repetitive, homogenized products.
Recently, I started playing with a (traditional) button-press that i got off craigslist. It is a lot of fun, and people like buttons (and pins, magnets, keychains, zipper-pulls)… but each different size/shape requires a different die, shells, backers, etc… and they all come out looking the same. That’s great for repeatability, but not so much for originality.
Safety pins are a great start. What other hardware might be incorporated in a similar way to make unique items?
At work, we use magnetic name tags for trade show. The button has a metal strip at the back, and on the inside of our shirt there’s a magnet that holds it in place. That could work here as well.
How 'bout nuts 'n bolts? First layer is just nut-sized cut outs. Second layer is made to fit the shaft of the bolt. Third layer is house numbers or something epoxied to a flat bolt head.
Looking at the instructions for that, btw, it seems as if a laser that could engrave/score to a specific depth could do the safety pin thing in one step. All you need is enough depth to get a glue layer over the back wire and a slight recess for the head. (Yeah, you’d need to be doing 2-sided registration).
Oh, I like the safety pin idea. I plan to make name tags for the local Lions Club when my Glowforge arrives. I have used these things in the past. I had also considered magnets. But I like this idea, too.
… I’m blown away by this!!! As a metalsmith, I’m used to soldering pin backs onto the piece. THIS however was just amazing, and clever problem solving. I love it and will add it to my arsenal of design tools
