Loving the way the paper engraves. I glued it on wood backing for a pendant. thinking I might use resin to seal it.
Wow, that turned out very nice! It looks so delicate!
Great result!
So did you glue then engrave/cut? Or did you cut and engrave the paper, then cut the wood, and manually glue it up?
Amazing result!
I cut some layers ones from PG Draftboard, painted then glued.
Ive done some 6 layer designs on 140 lb colored stock that I purchased at Michaels.
I engraved then outlined the mandala image with the new outline feature (loving the new features on the interface) cut out wood glued together. I work with resin a lot thinking i might put a nice resin dome on top keep it sealed.
ohhhh these are amazing love them!
I’ll upload the file in a bit.
Update - Her is the file I promised.
it’s the tiny pink speck
Update - Fixed tiny speck so you can see it. Thank you @wesleyjames.
It really is the file, I downloaded it myself to try.
Discourse does this all the time.
If you go edit the post you can add a zero or two to both numbers and it’ll boost the size.
1x1 into 10x10 or some such.
Those are GREAT! I need to lean paper and cardboard. Thanks for sharing!
Wow! That is so beautiful!
Nice turnout. Love paper.
wow that’s incredible!
This has inspired me to try paper! Love the design and color combination! Thanks so much for sharing the file!
