Marine-Grade Polymer
Wondering if it’s safe to cut Marine - Grade Polymer? If so, what settings did you use?
The specific material is called King StarBoard made by TACO Marine.
Check out #4 for guidance:
As for this specific material the answer is probably. Look for the SDS from the manufacturer, it should tell you, or at least give you a better idea. If you find it and want some help interpreting it, let us know where it is and someone will help you untangle what it’s saying.
Also, don’t be such a stranger! Welcome back :slight_smile:
