My husband, Jon, figured that we’ll be using masking tape a lot now that Festus is here ($10 4’x8’ sheets of Home Depot plywood work well), so he designed this masking tape dispenser. It’s 6" wide and will hold multiple rolls.!
try signwarehouse.com or uscutter.com, look for transfer tape or application tape, and avoid the clear ones; the clear transfer tapes almost all are pvc-based.
I personally like TransferRite 592U (hi-tack, on the red inner roll) for masking my own unfinished wood, and 582U(med tack, yellow inner roll) for masking aluminum, acrylic, and polyester wrap films.
I just ordered the 582U out of people’s recommendations, and i was thinking of designing a tape dispenser (for 18") too, now I guess I wont have to start from scratch!
Okay, I took this design into Inkscape and expanded it to 12" wide, then fiddled with it to panelize onto two 12" x 16" pieces of that 5mm plywood. Still has the same caveats as the original - fits only one way, not symmetric. There are some notes on one layer that will guide you. I set it up so you can save with all layers visible, load once into GF and ignore/cut different items for multiple cycles. It has Snapmarks to help align. Only item I am uncertain about is the little end-caps for the PVC spindle. I’ll try gluing them, but not sure about adhesion of wood to PVC. Might be better with PVC caps, so I’ll cut my pipe long to keep that option.Tape Dispenser 12inch.zip (15.4 KB)
