If only I had the space…
https://www.kickstarter.com/projects/maslow4/maslow4-affordable-compact-large-format-cnc-router
Quite an update from the first version. 0.5mm precision, pretty impressive.
Looks pretty cool. Now I wish I could get one lol
I can totally see @evansd2 making giant creatures out of full sheets of plywood.
Well I hadn’t thought of that. You are officially killing me.
I already don’t have room for the vast majority of my creatures, making an 8’ diameter version wouldn’t help things.
A creature you could step inside of would be pretty wonderful.
You can go pretty big with the glowforge as it stands…
Definitely. I backed it as an accessory for my 4x3 CNC. I can tile longer (4 by X) but this will be good for some of my furniture & cabinet projects.
I thought this might be the time I get a Maslow. Then I started to think about what projects I need it for and how much plywood is (then realized that proofgrade is a much as 4x8 plywood!). Convinced myself that if I made as many things with the Maslow as my glowforge, I wouldn’t have nearly enogh space. I barley have room for the glowforge projects.
Trying so hard to justify…
Combine it with the latest Easel addition that creates the file needed for cabinets (upper or lower) and you can build custom cabinets
I thought, “Hmmmm, I should build a shop so I can get one of these.” Then I thought, “I need to get one of these so I can build a shop.”
Wow, I wish I could get one! I feel completely in over my head just looking at it, but something that would be incredible to learn. So many ideas.
Less than 18 hours left to back it.
They’ve got 1456 backers which according to the update video they just released is a “sweet spot” in backers - enough to get it built but not so many that the Kickstarter gets unwieldy. They’re about 4X their goal (the minimum needed to build) so looks like a solid project with little risk. Now I just have to figure out where I’m going to put it
I am in. That is hard to resist. I have wanted a CNC for a while now and this one sounds perfect.
You’re not helping…
