This is really good advice. My cardboard almost caught on fire. Go faster and put card board in fridge prior??
Cardboard is flamey. Go fast, donāt cut super complicated jaggy lines with lots of fiddly details. Thatās whatāll set you on fire faster than anything.
BTW, that thread I just posted has pics of the magnet tabs:
I doublestack my bars, they hold down all but the most stubborn 1/8" wood.
Magnets work thru 3/16" warped cardboard?
Cardboard? Easily, it bends like a punk. Just be careful about total stack height. The air assist fan is about 0.5" above the tray. 3/16" only leaves you with 5/16" at most. Youāll probably be ok with a doublestack of thinner magnets, but just keep the total height in mind as you consider all this.
Also this might be of interest:
If you have a prying tool or dental pick type thing then you can dip the tip into a hole in the honeycomb and slide the magnet up the shank a bit until itās easy to grab.
Not a bad idea but the duct tape method works so well and requires no tools⦠Iāll probably stick with it.
I use the pick to see if the parts have all cut out the whole way so itās no extra effort to use it to slide a magnet for pickup.
When stacking magnets, or using them on thicker materials, be careful that the head of the glowforge doesnāt ādragā your magnet. I bought some very powerful magnets, 25lb of pull iirc, and they work great. But if I stack them and the laser head goes over them they sometimes pull the laserhead and cause its alignment to go all to heck and I wind up with a very interesting cut, or it can drag a single magnet with it leaving it somewhere it is not supposed to be. Later it goes over the magnet doing a cut or score and I now have a big uncut area in my design. Iāve learned to use these larger magnets unstacked and donāt place them on thick material where their attraction to the laser head will be greater than their attraction to the steel crumb tray.
But as evansd2 said, magnets will easily flatten cardboard.
That magnet dragging thing has been kicking around for a while. I personally havenāt had it happen, and just judging by the physics of the thing I have always been a bit skeptical. While I donāt doubt that your alignment got screwy, I wonder: have you verified that the magnetic field was the issue and not the air assist scoop? It hangs really low, it could catch a magnet pretty easily.
In any case, so far so good on my end.
One of the PRU users caught a video of it happening onceā¦the little magnets were just jumping up and catching the head for a ride as the head passed over. (It was totally cute/funny/scary simultaneously.)
Not only had a magnet move but had one jump off of the material and attach itself to the air assist port behind the head.
i have to wonder how tall the stack of magnets is or how close to the head thicker materials with thick magnets are. iām using pretty strong magnets, so theyāre never stacked or that tall.
Iām not sureā¦I wonāt use them. (Not just for that reason, but because I tend to hurt myself with them too.)
Magnet movement will only be a problem when the distance between the magnet and the head, or port, approaches the distance between the magnet and the honeycomb. A thin magnet and material less than 1/4" or so will never be an issue.
Maybe thatās why Iāve been in the clear. I donāt screw with anything over 1/8" really. Like I sad, the physics just never seemed right to move the head without the magnet straight up jumping to the head.
My problems came with 3/16" material and a double stack or a single magnet with 3/16" and enough warp that it was still off the honeycomb.
At first I couldnāt figure out what was happening and thought I had placed my magnets over a cut line. Then it happened when I knew nothing was close to a cut line. The odd thing was I would watch the head go right over a double-stack with no issue, so not a catching on the head thing. The very last time I watched the magnet being towed, so to speak, across the material. It was towed right under a cut on a pretty simple design - just my luck.
There have been one or two times when I have placed a magnet under a cut or score and didnāt notice until it was too late. I have one magnet with a partial snapmark scored in the gorilla tape. That one was my bad.
