So, I’m a new user and my Glowforge finally arrived this past weekend. I’m having a ball learning to use this thing.
For those of you that use materials other than proof grade that Glowforge sells, how do you go about figuring out if a material is safe to use? Do you just roll the dice and hope nothing bad happens? I’m hoping there’s a safer way…lol!
Also, what are some specific materials and where did you purchase that you’ve found work well and are safe for use?
Very bad idea to guess:-). Do a google search of laser safe materials. ALWAYS avoid PVC (chlorine). There’s lot of discussion in the forum. Do a search of something you ‘want’ to laser and you’ll probably find most of that info right here in the forum.
What they all said - and also, there are many vendors that work with laser cutters. When purchasing look for materials that confirm that they’re laser safe. We’ve gone from a niche to a large percentage of maker materials purchased so companies are getting that information out there front and center.
