Anyone have any experience with the types of setting one might use to cut these? and also to score them? I prefer to use 1 pass if possible because foam melts and the more passes I use the more melting occurs and I lose size.
As a starting point, I have settings for 5mm foam I get from Michaels at 325/100 (I have a Pro but 100 should be the same for all). Cuts very nicely for me. I think it’s Elmers brand, don’t have any leftovers with stickers still on them.
Thanks for the spreadsheet link. Although it doesn’t have a lot of foam options, other materials listed would be helpful down the road.
I have tried laser cutting 5mm foam from Michael’s (they’re really just soft and low quality tbh), and I’ve experienced kerf, but it’s inconsistent due to foam melting which is frustrating.
Again, the spreadsheet isn’t nearly as good as a quick test. You can get it exactly right in 5 minutes, less once you set up the test file in the UI. Testing is so fast once you have that file setup that it’s quicker and more accurate than posting a question about settings.
