Hey! Has anyone tried engraving those mini wooden bowling pins? I’m having trouble it keeps saying that the item has to be between a certain height but the pins r only 2inches thick which should work
You might need to make a small jig to hold them, that the top of the jig is 1-3/4 or so and then use set focus on the top of the jig. Also make sure that there is no PVC plastic involved as even that much could destroy the machine.
Thanks!
