It’s been a minute since I’ve shared a file and this one actually turned out good without any finagling so I figured I’d go ahead and share this one. It’s the miniature shim-lock open-backed display shelf that I designed for my Adventurer’s Supply Shop diorama. Cut red strokes first, then black, medium proof grade draftboard. There is one extra shim in case you need it. To assemble, insert the tabs of the shelves through the sides and put a shim down in to the hole, with the 90 degree corner of the shim against the side of the book case. The shims for the bottom shelf will probably stick down past the bottom of the sides a little, just snip off what extends so it sits flat. The top shim will sit close to flush with the bottom of the scoop on the side piece. I used no glue. assembled size very close to 3.25" tall, 2.29" wide, and 1" deep. Each shelf space has just a hair under .75" clearance. Personal use only, of course.
Right click and save as:
Photo of assembled, colored with brown Sharpie:
Thanks for stopping and taking a look, and until next creation, Happy Forging!
