merlin.ai.zip (698.9 KB)
Thanks! Give me a few to take a look and see what’s going on…I don’t see that when I open your file.
FWIW, mine opened the same as yours; no fills, no significant issues that I see at a quick glance.
That one looks like it was based on mine in that I put that red stroke around it as a cut line. It is that red stroke that causes the whole thing to load as a black circle. Opened the SVG in AI, clicked on it and hit delete and the artwork was still behind it. For some reason that outer circle is showing as filled when it is not.
here’s a new one, I realize what it did to it. After the trace I expanded everything to make each line a new stroke and fill (used to do that for other workflows). Creates a mess obviously when making an SVG for a laser cutter. Here’s what it should have been. Tell me if this looks better to you.
I note that file will warp just like mine did the other day! That’s a lot of material removal…
Yea, I’m glad you mentioned that, have to get that in my head so when I actually get my hands on a Glowforge I can hit the ground running. I was actually just playing with the file (origianally) to see if I could get something that @Xabbess would like the results from better than just trying to engrave the jpeg off Goggle images. And I want to start thinking more Glowforge when I’m in AI and not as much other types of artwork
And just to clarify for those using the CC version of AI there is the option to just ignore any white space in the first place in your trace, that way you can skip this step
You have no idea how annoying it use to be to find all those trapped white spaces for some other type jobs I used to do.
I dug around a little on Google Image Search (using reverse image search) and found that this was an illustration by Sir Thomas Malory. Knowing that, I was able to search for Merlin Sir Thomas Malory in Google image and come up with some better results.
This one has a bit more resolution but it’s just a much cleaner file overall. Somewhat interestingly, Alamy is selling a reproduction of it as a stock image.
I guess they figure Sir Thomas Malory won’t be complaining ![]()
Huh! That is strange…the original SVG that I downloaded and opened in AI opens up looking like this:
And you can see that the fills are listed as white and the strokes as black.
The SVG created from the AI file that you just loaded looks like this:
And the fills are listed as null, with the strokes as black.
No idea why there is so much discrepancy between the two. (Maybe Discourse is getting involved as well, or that first download was corrupted.)
Trying to convert the second one to an engrave in the GFUI will result in this: (After the clipping path is removed).
I think it’s still going to engrave in the “white” areas, although not as much. (But the net result is going to look like a black circle on the board, and you don’t want to just cut it.)
From Ken’s second file, (which is a jpeg, I think), I was able to create this: which is just about identical to Philips file, so you can just use that one @Xabbess - he even threw in a cutline for you.
This does absolutely nothing to teach @Xabbess how to design in her own program though…so the next time she needs a file, she has to ask Philip to make it for her. ![]()
If you guys with a little more experience want to get ahead of the game on your designing, I put together a list of the design rules for the GFUI back in December that still holds:
And there will be some step-by-step tutorials posted later.
So check out that list… If the PR folk want a little more instruction or to look at the tutorials now, let me know…just shoot me a PM. ![]()
@jbmanning5, thank you for explaining this so well. I had not actually understood what all the talk about multiple paths was about until your post. It clearly shows what is going on. Great job.
Lol, the second one was supposed to be the cleaned up SVG, must have clicked on the wrong file. And though I would never hesitate to help @Xabbess any time she needed it, the reason I converted the file was just to see what it would take since I haven’t had the chance to work with the Glowforge yet. To be honest that’s why I’ve been a little shy with writing any tutorials. Outside of basic interface I’ve found teaching anybody anything in programs like AI is always very heavily influenced by the context. I’ve taught lots of people in different situations, but with something as complex as AI or photoshop (for me) where everything can be done a dozen different ways, until I can verify for myself the techniques and principles I’m using actually work for the situation, then I’m a little more hesitant to open my mouth.
for instance the first SVG I uploaded with the terrible overlapping paths would work just fine for screen printing, but obviously not so much for a laser.
I made a tutorial that covers this. I wasnt just giving her a fish, there are instructions attached =P
Yeah, I understand (oh, for heaven’s sake, Discourse is telling me I talk too much again…) the need to try it out ahead of time…take a look at the “Rules” on that little Guide.
If you are already familiar with Illustrator, they’re more than enough to get you going.
Matter of fact…you can design a few ahead of the game, and be ready to test it when the machines arrive.
That’s one type of overlapping path that can pause a problem. Here is another type, from another discussion:
Fantastic! I’ll just get back to designing.
Wow…this is stunning!
The tracing of a bitmap to make vectors and then working with the file to make sure fills are fills or at least combined as an object to engrave and what you don’t want to engrave is not filled is a big challenge but necessary. I have so many files that I have been working with and playing with to get a vector to engrave rather than a raster to engrave. This is something you need to do if you are doing stamp and in reverse if you are doing inlays into an engrave. Thanks for everyone joining in and contributing to the discussion and furthering my education.
And for a brief second I thought about opening my old CS version of Illustrator to try this out. Slap hands, Bad boy. Stick with Inkscape and figure it out.
Heres an updated version made from the higher res image. cut line added as well
merlin_tak.zip (277.2 KB)
