These files are designed for a tight fit using Medium Cherry Plywood and Thick Glass Green Acrylic — joints and slots may need adjustment if your materials aren’t quite the same thickness as mine.
It’s also designed to exactly fit a Satechi 4-port USB-C charger, and expose cable routing for only three of its ports (the fourth going to the MagSafe charger puck). So you might need to mess with the design if you’re getting different hardware.
The design is included, and is printed on proofgrade materials so you would use default settings. If you use your own materials, you’ll need to figure out the appropriate settings as indicated in the original post.
Nice share. thanks. Good timing, My ancient multi port charger is failing so it is time for an upgrade. This will be a huge improvement over the current tangle.
