Great job! That looks close to the 2 inch max but engraved well!
The bottle is Ø2,7 inches
How did you position the pan to get it to engrave. And, are you using Cermark?
I´m using Cermark, and i did cut out an opening in the bottom of the Glowforge to make it possible to handle bigger objects.
Its the first modified Glowgorge I know about.
There are others out there
I guess so, but I have´nt seen them yet.
Although I´ve been searching.
I’ve had good results with dry moly lube…and much cheaper than Cermark etc
Thanks, I thought this might be the case. Brave soul
I did´nt succeed to find moly lube in Norway.
Well, then Cermark it is👍
Not the only one.
Knowing the shipping hassles to Europe I can see you figuring you will never send it back for repairs.
Some of the rates appear cheaper to buy a new one than pay the shipping for a refurbished unit.
