These are super waterproof and very thin. Probably the combo of the polyester and laser printing.
Nope. The photo is printed on a slightly shiny white sticker material sheet that you just run through the laser printer, then peel off the backing and stick to the draftboard.
These are great!
I am personally looking for something higher end but your techneqe will come in handy for many things.
Iām about to run up to Michalās and get some glue/laminater and then to HF for some foam brushesā¦
I have masking on the way, everyone needs some but I like how you reused yours. Oh! I need to get a roller while Iām out.
Oh I see now. Thanks!
Thatās pretty great. It looks like they also make a similar product for inkjet as well.
https://www.onlinelabels.com/Products/OL177WJ.htm?measureunit=decimals
The problem with that one is it is vinyl based.
Iām looking, but Iām not seeing where it states the material.
Itās deep, if you donāt find it Iāll post it when I get home to a real computer.
I dug around a bit. But if you donāt mind posting it, thatād be great. Of course, if you donāt feel like it, I wonāt mind! ![]()
Hereās a spot that says they are vinyl based. Not sure if it is PVC vinyl, or hey are just using it as a generic reference to a plastic material. They did respond quickly when I asked for verification on the material in the polyester laser printable ones.
