Okay, I built this with CNC sometime back but I’d love to see it built with laser cuts. Tweak to your content and share what you did.
The wood should be 1/4", I used baltic birch. The holes as drawn are for 1/8 dowel but again, tweak as desired. Cut as many headband pieces as needed for your headphones.
This slips onto a wire shelf as shown, but of course, you can rework the mount as desired as well.
mountspacer.pdf (82.4 KB)
headphoneassimbly.pdf (88.3 KB)
mountplate.pdf (82.5 KB)
frontcap.pdf (152.5 KB)
spacer.pdf (82.8 KB)
plate.pdf (82.2 KB)
EDIT: here is the fusion file in case someone is using fusion 360 and they’d like to tweak the design there.
http://a360.co/29SvCku
