I had these magnetic 4" vent pieces for another project and thought they might work perfect for this! It is super easy and fast to set it up and disconnect it… I only need to vent while it is use then I pull everything in and close the window… so now I just roll the table and disconnect the magnet. The set up is a tube out side connected to the wood. then on the inside of the wood is a magnetic vent adapter. Then the other half of the magnet and a fan is connected to the GF hole. I just pull the magnets apart and take the board in the window and close it! With the added fan it sucks a lot of the smoke out of the machine after the GF has stopped and it’s fan has turned off.
Nice job! I really like your rolling table. Could you please share where you purchased it and what they call it. It is exactly what I’m looking for.
Good planning!
Thank you!! I was so sick of dealing with pulling a long hose in every time. I only connect it to outside when in use and then pull everything in and close the window… so it made it a pain… this is so quick and simple! I love it! here is the table… they have them on ebay for $130 sometimes… and Sams club also has them… I think amazon too… but more expensive on there. https://l.facebook.com/l.php?u=https%3A%2F%2Fwww.ebay.com%2Fitm%2FWork-Table-with-Stainless-Steel-Top-49-FREE-SH%C4%B0PP%C4%B0NG%2F291602292686%3FssPageName%3DSTRK%3AMEBIDX%3AIT%26_trksid%3Dp2057872.m2749.l2649&h=ATMZ_0jqkIdDYjkDQa_iM6gpkK9f-KEcgRVEZKFIk8GUgoVDkTQrQ6WpxJEKbt911i3U9o_FqfMi6DGRbqS_arWM3HjMA57fIpb4ECbmD0uuVuv5kvk1ILNwzHtwg9ge_Lkr
and then here is the cheap little 4" fan that is connected between the magnet and the GF
https://www.amazon.com/gp/product/B01C82SYZ0/ref=oh_aui_detailpage_o02_s01?ie=UTF8&psc=1
Thank you for taking the time to find something similar. So you already had your table? My laser is sitting on a heavy duty oak table and the room doesn’t really have much extra room, but I’m thinking a table like that can be wheeled somewhere else when the grandson visits. Cindy
thank you for the table link! You’ve got a great set-up!!
Thank you! I was looking for a table I could easily move if I needed to for what ever reason! This one was perfect! and fit the GF with a little room on each side!
Global Industrial supply also has all the parts for making rolling tables/carts like that (and a few premade). That’s what I would have done if not for ikea.
Just a FYI as it turns out the 10oz Folger plastic containers are just the right size to fit the 4" exhaust hose. Cut out the bottom and you have a quick disconnect or don’t and you have a cover for the hose.
