I am a purchaser from the initial semi-crowdfund span, received my glowforge more or less when expected for someone at that point on, and to this point I have only used the glowforge a small handful of times. I have most of my initial materials more or less untouched, and haven’t spent any of my store credit (and I think I missed the window for founder discount? At least it was supposed to have ended by this point, as i understand it)
The reason for the delay: I am autistic, and not a terribly high-functioning one at that. I have made repeated attempts to work with tools to produce files for the glowforge, but I run into difficulties in that all of the available software appears to be some combination of extremely complicated or lacking critical features unless you spend incredible amounts of money.
When I try to work with the more complicated illustration or cad packages (inkscape, illustrator, and a few 2d cad programs I have tried), I end up overwhelmed with everything in the application. There’s so much to interact with, and frequently much of it is necessary to accomplish the most simple of tasks. Even making simple boxes appears to be complicated beyond my ability to fathom, and most 3d cad tools appear to be even worse.
I’ve found that I can work with sketchup – its basic usage is intuitive to me, and I can ignore most of its functionality without suffering significant stress – but the free version does not natively export to SVG, the ‘pro’ version is expensive to the tune of a significant percentage of my yearly income (or else I would pay a subscription which makes no sense for me as a disabled person on fixed income), and the one plugin I found that attempts to produce SVG output from sketchup ( face SVG ) is meant for CnC routers and produces output that must be then post-processed by something like inkscape putting me back to the previous set of problems.
I’m at a bit of a loss. I see some tools that I might be able to use, but things like TinkerCAD are web-only offerings, and the idea of not actually having an application I can install and back up and control when it gets updated changed is an additional stress factor for me (at least with Glowforge there’s already a monetary investment so I have at least some reason to trust things won’t change unduly), so I can’t bring myself to invest in the time to familiarize myself with a tool that might suddenly stop being usable at any point in time.
Does anyone have any suggestions? Are there any 2d programs for producing SVGs as easy to use as sketchup, and I’m just missing them? are there any cad offerings like tinkercad that can actually be installed as a standalone app?
Alternately is there something easier to use than inkscape that is capable of post-processing the output of face svg?
I wonder if the Sca Laser program is easier? do yu know if this will work with glowforge? i use designspace with cricut
