Need help with selecting design software
boxes.py is a great tool for making simple boxes - it generates an SVG you can download and use straight away in the glowforge.
I’ve learned inkscape as well - and as long as I color each “process” differently, and cuts BLACK, then that works well too. You do have to make sure to select text, then path, then object to path… so you can then engrave it.
