how do you split a svg file on glowforge software so you can print the file on 2 different pieces of wood?
You’re probably going to need to split it in some other design software - Glowforge does not provide that ability. What program are you using to do your design? (And what kind of file is it? Raster(pixels) or Vector?)
Split in half or split up according to different parts of the design?
Use different colors for the vectors, but you have to use design software?
There are several tutorials on this in the tips and tricks section.
it says svg not sure on the other all i have so far is glowforge program
it won’t fit on layout its to big
