That’s pretty interesting.
So cool!! But I think it resembles a Bacta Tank more than a replicator
Innovation FTW!
Oooh! Might be looking at my next toy! (Bet that won’t cost much.)
When they did the TEDTalk presenting the future Carbon3D, I thought it would be a prosumer but affordable printer, because other than the new “no peeling” method it was a regular DLP printer. Then I got depressed when they announced the price…
There are many versions of that technology, all merging together. It’s exciting to watch. I’ve even seen homemade versions with an old home projector and a rotating tank that did pretty good.
Very interesting, sls but with a major sw update. I’d love to see FDM get a similar treatment despensing with conventional slicing.
The software to do this must be something fierce. The inverse of a CT scan.
Thats pretty cool.
I don’t see this as that hard of a software problem from what a I read.
At least not all that different than a typical slicer. Instead of a moving plane up or down along the Z(height) axis you have and a or b axis that the object rotates the plane through. There is probably a better algorithm than convert to polar coordinates and create your slices based on fixed values of theta.
I’m not trying to diminish their creation. I see all the time it seems people that just see things a little different and everyone misses it till pointed out and then it seems obvious.
I compare this to a 4 or 5 axis CNC or a CNC lathe doing a circle vs a traditional cartesian 3 axis.
I’m pretty sure you are suffering from Kruger/Dunning right now. (That is nothing to be embarrassed about, it happens to all of us)
Even the algorithms to convert a body to 4 or 5 axes are moderately complex, the G-code is simple enough but the process that has to happen to get that G-code can take a while on a PC if you don’t have a good gamer or workstation video card installed.
This would be several orders of magnitude more complex because we are no longer just worried about mapping the surface but the whole body. Like previously stated, a CT or MRI but in reverse to create a series of images that will sync with the B axis.
If you are good with maths, or even if you are not, take a look at this and then think about reversing the process.
well my head is swimming now. wow!
Your welcome.
