No glue required
I was going through some of the free designs I had downloaded a while back. One had an interesting joining method. Using friction instead of glue. I figured I’d work on it a bit and see if I can make something a little better.
Introducing, self locking tabs. Just slide together until they pop into place.
Still needs a bit of tweaking, just a tad more play than I was hopping for.
Here’s the SVG if someone wants to play with it too.
Locking Tab Test
Very clever! :grinning:
I have seen a lot of variations on locking spring joints for 3D printing and have used a few in the past. Sort of forgot about them. Lots of ‘Oh Yeah’ happens when lurking here, lol.
I will have to go back and examine them now I imagine, since Glowforge seems to handle complex rather nicely and the living hinge concept makes many of them feasible with wood.
I like the simplicity of your find and it would work well if excess overhang is not an issue.
Below is a fast and dirty locking spring joint concept sketch. I have a pre-GF file in the works that is using slots for joinery, but may rethink it using a spring joint idea instead.
spring
Thank you. I look forward to playing with this.
Wow that’s really great! Thanks for sharing the technique!
Don’t forget about the Stanford snap fit.
https://tltl.stanford.edu/project/universal-snap-fit
Neat! Maybe next you’ll adapt these tabs for non-orthogonal angles? :slight_smile:
