No Soliciting NEST Doorbell Surround (2nd Generation)
Just moved into a new development and the vultures are bad around here.
I used Thick Black Acrylic and it is very snug and fits nicely.
NoSoliciting_Nest2DoorbellSurround
I don’t have a NEST (nor do we have many people going door to door), but that’s a nice share. :slight_smile:
Agreed. I really like that!
Thanks! How cool is the tool that allows you to iterate so easily with such good results?
They are blocked from entering, but the phone rings so constantly we can only get back with messages. I need something that would feed back a flashing red light unless you knew the code to actually get through.
We don’t have a Nest either, but I really like the style. Thank you for sharing your work.
I love this!
awesome wish someone would make one for a ring 4 doorbell…
If you send me the dimensions and a Picture, I would be more than happy to try and make you one
Sweet I can do that. Thank you kindly!!!
I modified your design slightly, and put it on my nest, though we may have different versions of the device. I need to measure mine and shorten the design.
I am watching you
I should probably also patch that hole behind it, and finish priming the door frame… Hmmm. edit commentary → maybe I shouldn’t patch the hole, it contributes that “go a 'vay” vibe.
Maybe it needs an All Seeing Eye on it also…
I may do the same for my Eufy twin-cam doorbell but put a “ring here” arrow since people keep pushing the two lenses and then the button :smiley:
nice
Looks great! Thanks for sharing
My neighbor has a Ring Doorbell but they are not sure what version it is but they believe it is the latest version. Here are a couple of designs. You could cut it out of Cardstock or Cardboard first before you waste any expensive material to see if it will fit.
NoSoliciting_RingDoorbellSurrounds
Awesome thank you kindly sorry I have had my hands full and haven’t had a break to get the measurements but again thank you
