The Norton White Tile Metod post has officially been derailed (or should I say de-warped) into a Star Trek fans discussion.
“Make it so.”
Hey @primal_healer, can you share your belt cleaning method? I just did a visual inspection and mine look really crappy. Is it something I can do without taking the belts off?
Not sure if mine is a good one or not but what i did was remove the x belt from the plate brushed it down and cleaned with soapy water and a tooth brush. I;m sure there is a better method out there just didn’t have the time to search for it.
That’s about all you can do, any solvent will likely attack the material.
I have small soft nylon bristle brush attachments for a dremel and have used it to clean similar belts on my x-carve, but never on the GF.
I am anxious to try and laser green clay that will take the heat-shock and still hold together. Raku clays specialize in this but are meant to cool quickly and not heat quickly.
However, if the green clay can be lasered to metasilicate and the green clay surrounding it made soft and washed away, pieces of incredible intricacy could be produced ![]()
I would be interested in outcome of green clay experiment.
Latest tile i made for my uncle, it is his recipe my grandma stole and put in her cookbook. Hard to decide how to fill out the sides of the tile as the aspect ratio is a bit of a pain and doesn’t match up to many tiles i have available. I think my uncle will like it either way tho.
Wow, that is awesome! I am sure he will love it!!
A heirloom piece to be sure, that just rocks.
Found this thread the other day and was intrigued. I made these coasters for my daughter. I found that the results are really dependent on the processing of the picture. I processed one picture two ways and used the same settings (thanks @beerfaced) and got these results. Thanks to all those that worked out the setting for the Norton Method.
Very nice. You have it nailed!
Curious what models everyone is using. I attempted using 240 speed, 13 power on my pro and the results looked great until I wiped the paint remover and I found I had only barely etched the paint.
I guess that goes to show that calibrations take time, but save more…
I have a basic model. Here are the settings I used from @beerfaced post: My take on the Norton White Tile Method
All the ones i made were on a Pro
Mine were on a pre-nerf Plus model with the 45W tube.
Thanks. I now have The Pop Shoppe Bubble Gum pop on my screen. your comment was immensely funny.
I have a question that hasn’t been addressed before, as far as I can tell.
When I lower the power to anything below 40% my laser head moves as if it’s working, but there is no laser. I tried a quick test on cardboard and it was the same, so reflection isn’t the issue.
It could be a problem with my Glowforge because I haven’t used it for a while, but I cleaned it before trying to engrave and the cameras and mirrors are okay. And once I increase the power it works well.
I am trying to finish 24 4" coasters in the next 3 days, and I’m dealing with a simple design, so I may just go the Sharpie/Magic Eraser route, but I would like to try doing something like the photos I’ve seen here. They are incredible!
Thanks to all of you for sharing you ideas and experiences. I’ve learned so much reading what’s been posted.
It is unlikely that there is no laser beam when the power is set to 40 or less. Can you test this issue by putting some cardstock or construction paper in your Glowforge and setting a small circle to engrave at 1000 speed 20 power 195 lpi. I think you may have something going on with your file or your settings, but not your Glowforge.
