You don’t actually need Snapmarks to do any of that. But…
It might be cool to test using a piece of paper with Snapmarks on it already to write a message and then see if we can capture the Snapmarks accurately in the trace. I don’t think I saw anybody try that.
Doing a trace with embedded Snapmarks would allow using snaps with a lot of different jigs potentially.
nope, snap marks were perfect and it happened on multiple files with copy and pasting the snap marks from the template to each one. I saw about 1/8" out of alignment when they were only about 4" apart and about 1/32" farther apart but at the top of the file. the 1/32" is good enough for my purposes but moving them to the middle makes it even better because it splits the error distance.
And you downloaded a new copy of the Snapmarks template? Or did you just copy the marks from the first one you downloaded multiple times? (If that one is corrupted, they all are.)
If it’s not the marks or a particular file, you might have an issue with your machine that you need to tell Bonny about on the Introducing Snapmarks thread. That’s the only one they are currently monitoring for problems with the Snapmarks, and they need to know about them to fix them. (Vertical lines should come out vertical.)
never re-downloaded the file. I don’t know how the same file as everyone else would be corrupted enough to display just fine but change the contents.
I linked the thread in there. I can see how compounding errors with printing and reading will cause alignment issues if you don’t place your snapmarks far enough apart because that doesn’t give the math enough space to tell just how level they are (similar to how a 4’ level is more accurate than a 4" level all things being equal)
I haven’t had success with Snapmarks yet. I will have to try them again with @Jules instructions in front of me.
I have a couple of questions that I may have missed in the writeup above.
I thought that the jigs themselves could be rotated (the point of the snapmark would no longer be pointed down)?
Can we have the two snapmarks be oriented one above the other (put both snapmarks to either the right or left of the jig)?
Finally, Is it possible to run multiple jobs, each with their own snapmarks (multiple pairs of snapmarks appear in the GFUI to delineate different combined “jobs”)?
I’m moderately embarrassed to even ask, but how in hades do you download the template on a mac? I am remedial, I guess, but it won’t download – it won’t even let me screencap the image when it opens in a new window (because it’s not a “standard webpage”). My options are open it in a new window and inspect element. And no amount of swearing at it changes that.
They can, to a degree. The snap will accommodate some rotation in the jig but it has its limits).
It was never a recommendation from Glowforge, but from my testing yes, with some caveats. They can’t be perfectly vertically aligned. IIRC, if they are perfectly aligned, it would flip the design 180 for some reason. The only way I got this to work, was for the bottom Snapmark to be offset slightly to the right of the top Snapmark.
As for multiple jobs with multiple sets of Snapmarks in one design, no, unless that’s changed but I’m pretty sure it hasn’t.
@Jules - I’m just now trying the snapmarks - of course, for a major project, and I’m not able to get the Snap to work. Using inkscape, the marks were indeed resized, but when I attempt to correct them to your specified dimensions. I’m not sure they are ACTUALLY the correct size because of the precision in the Inkscape toolbar (only showing 3 digits to the right of the decimal), so it appears as if they are slightly mis-sized (0.333 x 0.405). There is probably an easy way to change the toolbar precision display to 4 decimals to the right of the decimal, but I have not been able to find it. Any suggestions?
Good news is that for the project (putting company logos on wood presentation boards for a CXO meeting next week), I’m able to manually align the “incorrectly size” snapmarks onto my jig, and the (manual) visual alignment is amazingly good.
