So I made an on air sign.
The two passthru spots it successfully did are slightly off(in opposing directions) but good enough at a distance. I’m even wrapping them in led lights with an RF not an IR remote and will put it all in a frame.
If you look inside the circle, there is a vertical engrave that got stuck in the wrong spot when that super long area that sticks out the back, was …ran into. Quick cancel and start over but there it is.
Would heat gun treating the location work to smooth that back over? Should I look at sanding and buffing it out?
(I might not care as the distance it’s meant to be viewed at will be substantial but, as a crafter I’d like to know how to make it better.)
Also, would a gradient fill of some kind resulted in a better lit product(centered middle of mic and lighter outward) or would that mess too much with the image of the mic?
(I still have to clean and buff it all anyway. Crazy acrylic dust.)
