My Button is Orange I do not know what to. I have had my machine since 2019 and I haven’t had this issue Please Helpppp!!!
It could be a temperature issue – check the temp ranges for your model in the manual, and make sure you’re within that. It could also be that the head isn’t communicating with the machine properly – check the connections on the white cable that goes to the head, and the contacts where the head sits on the carriage. Here’s hoping it’s something simple!
Also remember its the temperature inside the GF, and since the GF is connected to the outside it could be colder than the room temperature.
- Basic and Plus: Between 60 degrees Fahrenheit (16 Celsius) and 75 degrees Fahrenheit (24 Celsius)
- Pro: Between 60 degrees Fahrenheit (16 Celsius) and 81 degrees Fahrenheit (27 Celsius)
