Temporarily unavailable.
I was wondering how to do this. Thank you!
thank you @Jules I am learning alot from you⦠
That is a great tutorial. The effects in the video work well with the video. I am learning a ton from you, although my favorite tutorial ( so far ) , is Laser Design Basics. Thank you so much for all that you do.
If you wanted to take the spots on the wings and engrave those total areas, not just the lines or the cuts, would you have to fill those spaces with a color and designate that color as āengraveā, then? Is there any other way to select their outlines and have the spaces enclosed by those outlines engraved rather than just etching the lines?
You fill the shape with color, and remove the stroke color. That will specify it as an engrave to the Glowforge interface.
Or make the shapes a different stroke color and tell the GFUI to engrave it.
There you go again. This may be pushing the threshold on my artistic talents (or lack thereof). I guess I will learn a lot when I get started.
Now Iām hoping I wonāt need to get extra laser safety equipment for the cats.
Filling the shapes and turning off the strokes removes all confusion for the interface. Trying to convert a stroke to an engrave in the interface itself can be an iffy proposition. If the paths arenāt completely closed, you can get strange results.
(Itās just the most certain way to ensure you are getting the engrave you want.)
Yeah, but then I have to retool a design for a different machine.
Yeah I know, First World Problem ![]()
quick question. Iām trying to understand what is meant by Fill and Stroke.
Am I correct when I make the following ātranslationā in my head?
Fill = color fill, as in the little bucket in most editing software that fills an enclosed shape with a specific color.
Stroke = the outline of a given shape or design. The thin line that defines a boundary.
So when you say āFilling the shapes and turning off the strokesā you are saying that we should fill the shape with color, and then once that has been completed, get rid of the outline of that shape? Iām not quite sure how to do that since every editing software I know will delete the interior color as well if the outline is deleted.
Sorry, that was poorly wordedā¦what I mean by getting rid of the stroke is just removing the stroke color.
You are correct, you canāt actually get rid of the stroke, itās what defines the shape. But if you assign no color to the stroke, it effectively becomes invisible to the Glowforge interface, and all the interface will see is the Fill color that you want to engrave.
Everything in the GF interface keys off of color.
Fill colors are Engraved.
Stroke colors are either Cut (default) or can be Scored if you convert it to that in the interface.
(Scoring is the āEngravingā for single paths, whereas Engraving fills in large areas of color with a back and forth motion.)
And while you can technically convert operations in the interface, sometimes the results arenāt going to be what you expect - because you forgot you had a colored stroke line in there somewhere.
that certainly helps, thanks!
You are one with the Matrix!
Thanks @Jules! Itās really great to get these sneak peeks of the GF GUI and see how it all works. Keep being awesome, we appreciate it!
And thank you for the heads up on that little edit.
Ah, excellent! So glad to see that setting up ordered cuts is so easy in the GF UI. I do a lot of work that has cuts that definitely benefit from being made in a specific order, so this is perfect!
