My daughter sent me a photo of some earrings she liked, except she wanted them in a teardrop shape. That same day I happened across the exact cutout design on a Steve Good lantern pattern, and he noted that it came from Freepik.com. I couldn’t find it on that massive site, so I sent him a donation for the lantern pattern and lifted it from there. This is the end result, currently undergoing wear testing: ('Scuse the sawdust I missed when I blew them off!)
I think if you do them again you should put the grain the other way - but knowing how padauk glows I’m bettin’ those are even more beautiful in soft light!
I cropped it because it was a reject due to the burn marks. But this is the whole thing. (Actually it’s the second pair I made, but on the same card. )
I have been making earrings with intricate patterns from blood wood, purpleheart wood an cherry wood. About half of the purpleheart and bloodwood break before the wire loop is installed. The cherry is much stronger, but not as popular. I have been think about glueing two 1/16" pieces together with the grain crossed, so that they will be much stronger. However, I think that the thicker wood would not present as well for an earring. What do you think?
My experience with paduk is that it is plenty strong enough for anything. a bit of furniture oil after sanding with even 2000 grit before can make an amazing difference
