Has anyone painted their acrylic after it’s been cut? If so what is the best type of paint to use and sealant? I made a couple of keychains to get my feet wet and hand painted them but I hate how they turned out. Is it anyway to properly paint acrylic after it’s been cut?
Nail polish colors are designed to smooth themselves out and can be quite a rabbit hole. Also Rub-n-Buff
Omg I didn’t think about using nail polish! Thank you! Is rub and buff a sealant?
Rub-n-Buff seems more a wax where I used it on acrylic it did not all come off but on wood it is almost fugitive.
Wow, I can see how you could make some amazing designs like this. Make the picture a mirror image and cut/engrave, then fill in with paint and flip it over. Could make some really cool designs! Thanks for the ideas!
And be sure to do the painting/infill of the engraved areas before you pull off the masking. It will help keep the unpainted parts pristine.
This.
You can put down multiple coats of paint (I generally use cheap “craft” acrylic) before removing the masking, to get a solid, smooth, opaque result.
Good points! I have been considering removing the top mask, because it is such a pain to get it off of the engraved areas (if they are light). But, that is a good point about the painting. So, I guess if I make sure the engravings are deep, that would work best.
I saw a video last week about someone using alcohol inks (it was Fresh Start Customs I believe) and that might just give you a look you would like.
thank you so much!
