Paper Star Generator
Correct! There are two identical [1] star pieces that glue together with tabs around the central seam.
[1] Well, almost identical. One piece has some extra bits for mounting the electronics.
Here is a basic template for my star. Replace the olive-colored outline panels with your preferred latticework or scrollwork (or some simple small cutout shapes, etc.). Blue lines are mountain folds. Green lines are valley folds. Purple lines are cuts. I score the two sides with the flip jig technique.
Glue the tabs and press the two halves together. I’m just using a glue stick. Let dry completely. Then, you can gently puff it back up.
OnePieceStar-12cm-Paneled-DoubleTab
(Right-click, save-as to download)
great find. thanks for sharing.
Thank you for the share and the how-to!
Thanks for sharing! Very neat to have a two part design!!
