really like this cinch. I made masks for my husband and me. This works great. Thanks
My mom has been making masks and looking for ways to make them more adjustable. She tried the cinch but it was a little tricky to use so she requested a single hole version. I took the same hole from the paracord cinch and just put it in a circle. I found 1/4" to work much better then 1/8". With 1/8" the cord seems to want to loosen up. With 1/4" it seems to hold the cord in place.
This Paracord nay Elastic Cinch is the bomb! I’m using 1/8" elastic in these masks I made for coworkers at a medical clinic where I work. We started using this pattern because it doesn’t go around the ears, it has a pocket to hold a filter if needed, it can be put on one-handed, and you don’t have to touch the mask to take it off. I sized up the file to 1.25" to make it easier to fit the elastic through. It holds the cinch really well. Thanks for the file!!
Awesome, I’m glad the cinch worked out for you! I’ve started up-sizing the file for paracord as well, I should note that in the original post.
