I am putting together a laser show for Halloween and have been learning about standard interfaces and available SDKs for controlling RGB laser scanners.
Here is my first test of the end-to-end software:
And now I have a new profile picture for the forums!
Good to hear @dan! To produce this laser animation, I used a 1000mW RGB laser that supports the ILDA and DMX control standards. This particular laser also plays animations loaded on a SD card. The unit has three laser diodes, Red (638nm) at 300mW, Green (532nm) at 100mW, and Blue (450nm) at 600mW.
To control the laser, I use an Ethernet to ILDA Digital-to-Analog Converter (DAC) called the EtherDream. This allows me to control the laser scanner from any device on my network, including an iPad.
To design the animation and run my laser shows, I use software called LaserShow eXpress (LSX). LSX enables you to combine audio, pictures, and effects - including effects expressed as mathematical formulas and functions - to create a laser show.
