Polyisocyanurate Foam Boards
Hi,
I want to engrave Polyisocyanurate Foam Boards (go board) to create an outline for the mosaic projects I do. Everything I’ve read looks like they are safe, but I have no idea and don’t want to kill myself or my machine. I also have no idea what settings to use.
This is the info sheet I found on the product if that helps. https://www.jm.com/content/dam/jm/global/en/MSDS/200000000078_US_EN.pdf
I’m so sorry if I sound dumb - but I’ve scoured the boards for something like this and I just can’t find it.
Please help!!
Welcome to the forum.
As with all non Proofgrade materials, you will need to test to get your settings dialed in. Consider scoring rather than engraving, and consider creating a cut out template (stencil) of a known, safe material as a guide rather than engraving directly on the insulation board.
I’d be nervous for yourself based on:
Hazardous combustion products: carbon oxides, nitrogen oxides, hazardous combustion products
Conditions to avoid: Heat, flames and sparks.
Hazardous decomposition products: hazardous decomposition products formed under fire conditions.
That they don’t define “hazardous combustion products” and what you’d be doing is combusting it…I think it’s a no.
My opinion is different. If it is pure polyurethane, it will cut perfectly and the fumes will be sufficiently vented without concern. I wouldn’t hesitate to at least try a sample to dial in the settings, then if succesful (which I expect it would be), go ahead and use it.
This appears to me to be very similar (if not identical) to the board used for architectural model construction, and lasers have been commonplace in that world for quite some time - long before Glowforge.
According to a Gemini query:
No, PIR architectural modeling sheets are not safe to laser cut.
They are made of the same core Polyisocyanurate (PIR) foam as insulation blocks, and therefore release the same hazardous fumes when vaporized by a laser.
Regardless of the form factor—whether it’s a thick insulation panel or a thin modeling sheet—the fundamental chemistry of the material is unchanged. Laser cutting it will still produce:
• Highly Toxic Fumes: The process releases a chemical cocktail that includes deadly hydrogen cyanide (HCN) and carbon monoxide (CO). Breathing these fumes can be extremely dangerous. :skull_and_crossbones:
• Corrosive Acid Gas: Like most PIR foam, modeling sheets contain chlorinated flame retardants. The laser’s heat decomposes these and creates hydrochloric acid (HCl) gas, which will corrode your laser’s expensive optics, metal rails, and electronics.
I’d absolutely conduct a copper wire flame test before using it with your Glowforge.
Hi,
Please help!!
Hey all! Thanks for the input. I think I’ll just create a stencil like some others have suggested. Not worth the risk. Thanks again!
