The Glowforge part was simple. Getting the right amount of detail on the map without all the labels was… well… challenging. But the epoxy? Oy!
First I ran into parts where the color from the epoxy bled into the wood (seal any wood you don’t want to soak up color!) Then I got parts that didn’t cure properly (DO NOT scrape the last of the epoxy out of the cup!) Then the layers of wood separated and leaked (Make sure you have all of the edges well-glued before you pour!) But luckily maps can also be green, and epoxy is pretty forgiving if you’re willing to sand it and pour again (and again…and again…) Plus, when you sand the epoxy exposed edges of your now green wood get slightly sanded and it sort of looks a little like you MEANT for there to be a beach there…
But after almost 2 weeks on-and-off I’ve finally stopped working on my first epoxy/glowforge map of the northern New Jersey Shore:
Oh - and since I’m sure someone will ask, it’s 11"x17"
I love the dock though! So delicate
