Hi! Are there any sources of pre-finished hardwood out there besides
I like
of course, but I’d prefer a bit thicker than 1/8" if possible. Thanks!
Or any news on thick hardwood from
I like
depending on your local plywood dealer, most can get if not have prefinished plywood on two sides. they will usually be in 1/4" and a poplar core versus MDF. the one thing to consider is that you’ll likely have to purchase them as a full sheet, and the grade of the veneers can be lower then traditional cabinet grades. so make sure to ask about the face veneer grade. I hope this helps.
They were asking about hardwood.
For what little I use, I get it at my local Rockler which is 10 minutes away, or Lowes/Home Depot - but none are pre-finished.
There are many online sources, you can use the search feature above and find the dozens of previous discussions.
I couldn’t find anything about pre-finished hardwood sources
I’ve used prefinished hardwood flooring with good results engraving and scoring. Most is too thick to use the tray.
You might try https://www.coloradoheirloom.com
They have what they call hardwood strips that are finished on one or both sides. Thicknesses from 1/16" to 1/4".
Hmm looks like that might be good, but seems I’d need to have some kind of business ID to apply for an account. I guess I can check into that.
A true, hard-core hobbyist can always find a way around the wholesale requirement!
