Yeah you can make all types of cool stuff with it!
Oh mama! That is the stuff!
Have you tried doing a shallow etch to make it easier to stack perfectly-aligned pieces? If you can carve out just a millimeter or so, it would make assembling a complex design much easier.
its really hard to do on the glowforge right now. the power is too high and speed to low to get an even, non obliterating engrave. If you take a look at the white visor on the s76 helm it is on 1/4" material and went all the way through in a couple places on the lightest engrave possible. I have an old model though, the new ones might be capable of a lot more. also thicker material will have less issues. Maybe a lower LPI will allow for less obliteration lol
When assembling stuff from a cutout, a lot of times what I do is just leave it in the parent shape, and put the glue on the back side of it (just the pieces I want to stick), then line it up using that frame to keep it in place. In this case, I cut a red piece the same shape as the black piece, then cut the letters out of that. That way I could line them up perfectly, and then just drop the glued up letters into the slot to make sure they fit exactly where they were supposed to. Worked perfectly!
I do the same with acrylic. Like with this piece, which I did do an engrave first to slot in the letters:
Great info, thank you. Here’s hoping newer GFs can engrave with a lighter touch.
Stay tuned. ![]()
Hello. I just got my GF set up yesterday and am now scouring the forums for knowledge. Do you happen to have the speed to power to foam-thickness ratios you used to cut the foam in your photo?
I dont recall what they were, and it was on a PRU, so it wouldnt be super helpful because the settings are quite different on release units. Im sorry =\
No worries, thank you for responding so quickly. I’m running my own test now.
